Originally posted by nosaj
View Post
Crate GX-15R Schematic
Originally posted by chkline View PostWent ahead and checked real quick. Double check that I did this correctly, plugged in with power on, I checked capacitor C29 and C31, with the probe and the other side grounded to chassis, and could not find 15v on either side of the capacitor. Also checked the speaker output, and did not have voltage present there either.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by chkline View PostCorrect, amp was plugged in and turned on.
nosajcrate_gx-15_sch.pdfsoldering stuff that's broken, breaking stuff that works, Yeah!
This is looking confused. If any of the four diodes were shorted, D11-14, you would be blowing fuses or cooking the transformer. I cannot imagine all four diodes are open. Even one good diode would result in DC.
So connect your black meter probe to ground/chassis, set it for DC volts, and probe TP8, TP9. WHich happen to be the non-grounded end of main filter caps C28, C30. You should see something like 15v at each.
The only way I imagine you having AC at the diodes, but no DC at the TPs is if your CT lead is open. at the transformer connection. It is OK to see AC volts red wire to red wire, but there must also be AC from the green wire to each red wire. For that, leave the meter grounded to chassis, set for AC volts and then probe each red wire.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostThis is looking confused. If any of the four diodes were shorted, D11-14, you would be blowing fuses or cooking the transformer. I cannot imagine all four diodes are open. Even one good diode would result in DC.
Well, I'm feeling like a tool. The cord was part of the issue. I now have power, and it turns on, and the LED lights up, but the sound is very quiet and muted, I can hear the guitar through it, but just barely, and that is with the volume all the way up. You have to get very close to it, to hear it. I tried two different guitars as one is used, and not a known quantity, and both were very quiet. It will pop loud when turning off, so I believe it is getting good power to the speaker, anything obvious you all would suggest I check?
Thanks!
The jacks look very corroded or oxidized. They should get some de-oxit or similar cleaner.
What are the 3 jacks labelled as?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostThe jacks look very corroded or oxidized. They should get some de-oxit or similar cleaner.
I have my confidence high to fix my Crate Amp since yesterday, I removed and replaced a volume pot on a Marshall amp and it actually worked. Now I can't wait to finally work on replacing the I.C. Chip and the Op-Amp chip with the huge heat sink.
Joe
