Marshall Rear Output/Loop board issue 1 Schem needed
  • Marshall Rear Output/Loop board issue 1 Schem needed
    Does anyone have an Issue 1 schematic for a Marshall DSL output, loop board.
    The board number is JCM2-62-00.
    Thanks.
    DSL100?
      For a DSL 50. I thought they were the same for both the DSL 100 or 50.
        Maybe they are, does that drawing work for you?
        Here is the drawing from the DSL50. Ask for what you need up front.
          That schematics shows DSL50/DSL100 but is for the Issue 2, JCM2-62-02 board so they're definitely the same board for the 50 and 100 watt versions.
          I need the Issue 1, JCM2-62-00 schematic.
            The schematic calls it for the 62-00 trace art, this is the 02 version.
            How does your board differ? Do the differences affect the sections you are working on? These drawings are what the factory has provided me.
              I'll have to check if it differs - I'm looking at the effects loop.
                Yeah, the issue 2 schematic is different than the issue 1 schematic for the JCM2-62-00 board.
