I received this mixer with no information or power supply. It was working when stored a number of years ago but the PSU (power supply) is missing & Samick has been no help. I need a pin-out & voltages for the PSU and/or a schematic.
Samick Sytem 84
Is this a small mixer? How many pins is the power connector? Look inside and follow the wiring from that connector - what does it connect to? If diodes, then chances are the powr was simply AC. We can assume certain things, like the mixer circuits probably ran on +/-15v. What voltage ratings are on the filter caps. Are there voltage regulators in there? If so what ones? KNowing thisw stuff would let us come up with a reasonable AC supply.Education is what you're left with after you have forgotten what you have learned.
