I'm looking for an alternate schematic for a Rocktron Velocity 300 rack mount power amp that I have. Rocktron emailed me a schematic, but it doesn't match the unit I've got. The schematic shows the power amp with an LM4702 IC amp with SAP15N & SAP15P outputs. I've got TIP29C & TIP30C drivers with 2SC3281 & 2SA1302 output transistors.
When I bring the voltage up with the variac, it immediately starts drawing current & all of the LEDs on the front panel light - Power, Over Volt, and both clipping LEDs. It blows the ac line fuse if powered up normally. ac voltage on the transformer secondaries rises with the variac, so does the DC voltage on from the rectifier bridge - so it doesn't appear to be a dead short on the power supply. The output transistors appear to be OK. I'm going to disassemble now. Any tips would be appreciated
