swr basic black schematic
  • swr basic black schematic
    does anyone have an swr basic black schematic? edit: a layout would be handy too.
    fixing one with a hum problem which i am assuming is from the filter caps going, but i'd like to isolate the issue before bunging in some caps blindly.
    If your hum is twice the mains frequency, then it is power supply ripple, but if the hum is same as mains freq, then it is not the filter caps.
    Try a different tube in the preamp.
    The power amp is generic SWR, the power supply is common.
      thanks enzo. the guy i'm fixing it for says he tried changing the tube, but i'll try that again for a quick fix.
        For the internet's records, here is the schematic for the SWR Basic Black direct from Fender. I emailed them and they sent it to meBasic Black.pdfBias Procedure.pdf
          The 'Bias Procedure' pdf file is not coming up.
          Can you 'zip' the file & repost it?
            documents-export-2015-01-21.zip
            see if that works
              That worked like a charm.
