looking for schem to crate bfx50 bass amp
  • looking for schem to crate bfx50 bass amp
    Unit quit working after being hooked up to a pa system. Still powers on but no output.
    Found one for bfx100
    Found one for bfx100 seemed pretty close. Replaced both audio out IC's one was split open. Now I'm getting a buzz. Suspect shorted cap. The actual schematic would help a lot. Anyone??......
      Is it like the bfx50 found here?
      CRATE - The Best Value In Professional Tone
        Yes that is the one
        I have that but I am unable to get the schematic. I did find one for the bx-50 seems pretty much the same except for the effects. The part numbers aren't the same though. So far I have replaced the pair of TDA2050's as one was split in half and also plan to replace the two 4.7 ohm resistors on the output. They seem to test ok but look a little burnt. I'm not sure what else could be wrong. Any suggestions? Thanks....Jason crate bx50 amp.pdf
          Originally posted by weaverjsnw View Post
          I have that but I am unable to get the schematic. I did find one for the bx-50 seems pretty much the same except for the effects. The part numbers aren't the same though. So far I have replaced the pair of TDA2050's as one was split in half and also plan to replace the two 4.7 ohm resistors on the output. They seem to test ok but look a little burnt. I'm not sure what else could be wrong. Any suggestions? Thanks....Jason [ATTACH]8715[/ATTACH]
          Herewith attached BFX-50A. May be it will help you.
