BA115T
  • BA115T
    Anyone have the schematic for the Ampeg BA115T? I was using a BA115A because its fairly similar but now I've run into a problem that I think the correct schematic may help to solve, IE setting the bias for the output FETs
    Thanks
    i think i have the schematic
    check this if it helps..
    Hearing Is Believing
      Thats the one I already have, if you look in the lower right corner, it has the model number (BA115A). The BA115T has a preamp tube and I thought that was the only difference but now i'm seeing there are things on the schematic I have that aren't on the board I'm working on and vice versa.
      Thanks for the reply anyway!
        COntact Loud Technologies and ask them for it. I checked my dealer site for it, and the BA115T is an empty file.
        The BA115HPT has a tube, and may be the drawing to match.
          Yup, I had emailed Loud before even posting here. The last time I tried to get their help it was less than productive so i decided to try multiple paths. However, this time, they actually got back to me and I now have the schematic. I attached it for anyone else that might need it
            Thanks, I needed that one too.
            billy z
              I am in need of this schematic and the pdf that is attached is now a blank document. Is there any way you could repost it or email it to me? thanks!
                https://www.gearslutz.com/board/geekslutz-forum/495560-ampeg-ba115-schematic.html
                It's All Over Now
                  Thank you but I need the schematic specific to the ba 155T. That is the 115a.
                    Here you go: ampeg_ba115hpt.zip
