Need Behringer MDX4400 Schematic
    Hi Ian,
    2x 18Vac 0.4A is in my unit (basically it is 18V - CT - 18V, white-black.-white) and this is apparently the stock transformer. When you are in the 220V region remove the blue cable for the 110V Tap from the fuseholder so i can't happen that the fuse is inserted incorrectly and then having overvoltage on the circuit. If you have time can you do the measurements I mentioned in my last post and post your values here (or PM me)?
    Have fun!
    Stefan
    I can fix everything, where is the duct tape?
      Hi there!
      I just got a Behringer MDX 4400 and unfortuantely it doesnt work. When I push the Power-Button the Peak-Limiter LEDs light up a little bit, but then slowly fade until they're completely dark. Besides the Trannies get extremely hot, even after a few seconds.
      I can't find any obviously damaged parts on the boards.
      PS. It's the 220V Version
      Greets Nullzie
