Hughes & Kettner Switchblade 100
  • Hughes & Kettner Switchblade 100
    Does anyone have or know where to get the schematics for the Hughes & Kettner Switchblade series of amplifiers? I have one in the shop with no output and of course it would be grand if I had service information before I start poking around for with the signal generator and tracer. Thanks in advance.
    Barry
    Warning! Some Electronics devices contain lethal voltages that can kill you. If you do not feel qualified to work with dangerous voltages, refer your repairs to a qualified technician. By giving you online advice, I am assuming no liability for any injury or damages you might incur through your own actions.
    Got the schematic
    Ok, I emailed H&K and they return emailed me the 45 page pdf service document for the amp within 24 hours. Great response.
      Hi!
      I emailed H&K too, but they say to me that it's not possible to send me the service manual, could you send me a pdf copy? Thanks!
      Alessandro
        Originally posted by Tega View Post
        Hi!
        Alessandro
        Please send me too. Thank you in advance.
          Please, send me too switchblade service manual.
          Thanks!!!
          os-ds@yandex.ru
            me too please
              me too!
              parasite5983@gmail.com
                My H&K SB 100 just died. Could you please send me a manual too?!
                allengoodall@gmail.com
                  Didn't need the schematic
                  Just and FYI to all of you switchblade repairmen reading this thread. The amp I had in my shop had one power tube that was pulling high current though it was not "shorted". That was enough to blow the HT fuse in the amp. That is all that was wrong. If your amp has no output, check those power tubes and that fuse. The fuse in question is FU1 the T630ma fuse on the back panel. Remember that an ohm reading on a fuse does not always show them to be bad. Check for HT voltage at capacitor C1's positive terminal with the amp in play mode.
                    schematic switchblade 100
                    hi can someone please send me also the pdf file,
                    and If someone needs schematics they can't find, there are a lot in my personal archive.
                    thank you thank you..
                      Hi
                      Can I plaese have the service manual for switchblade 100 too?
                      Thank you
                      Kiesi
                      kiesi1@online.de
                        Send me that schematic too
                        I got the a similar problem as well with it blowing fuses. I would appreciate it if someone could send one of them schematics my way as well.
                          Switchblade Service Manual
                          Here it is.
                          Hughes & Kettner Switchblade Series Service Manual.pdf
                          Steve
                            Thanks man
                            Hey thanks, the tube tech i had working on it wasnt having much luck finding this service manual. Thanks you!
                              HELP!!
                              I just got a switchblade and everything works fine on the head, but the MIDI stageboard does nothing... I've tried the factory reset but it hasn't helped. The LEDs all turn on when plugged into the MIDI Thru input but it does not switch the setting on the head. PLEASE if anyone has any ideas as how to fix this it would be much appreciated! Thanks
