Summer Fund Drive:C'mon guys lets show some support! If this site has helped you an you haven't recently donated Include your username so I know whos donatingPlease consider making a donation. :)
On the support site, the schematic has a big old red notice in the middle exclaiming written permission needed to make copies. My service dealer agreement precludes sharing that drawing.
I can however answer questions about it. WHat problem are you trying to solve?
Enzo, I have a MG100HFX that has a dead power amplifier - the headphone jack works, and I can get a click from the speaker when I touch the base of the MJ15032/MJ15033 driver transistors. However, the board is filled with mostly SMT components, and I had no luck trying to use the MG100CDR schematic. Any suggestions ? The power supply measures +-43V, and the output transistors 2SC5200/2SA1943 appear to be okay.
Fixed !!
In desperation, I started probing around the SMTs with my DMM; lo and behold, there were TWO transistors that had not been properly soldered. I used 0.022 silver solder and now the amplifer plays perfectly.
