I have a Hughes & Kettner zenAmp combo on the bench with a NASTY pop in speakers when the amp is turned OFF (think "gunshot"). The amp seems to otherwise work but the turn-off blast will damage a speaker or two if not fixed! There is no DC present at the speaker outputs and the power supply supplies are balanced so it does not seem to be a power supply-related issue.
I tried to contact H&K through their web site and the e-mail gets bounced back as "undeliverable". They are in Germany and don't provide any U.S. contact info that works or that I can use.
Has anyone seen this problem? Does anyone have the Schematics available? Their mechanical design makes it quite difficult to troubleshoot without a schematic because all the components are buried from view and the amp needs to be almost completely disassembled in order to find the components!
Any help would be most appreciated!
Thanks,
Steve
Thanks,
Steve
