Peavey transistor cross reference
This is a sticky topic.
  • Peavey transistor cross reference
    Here is the Peavey transistor cross reference guide. Peavey house numbered transistors are mostly ordinary Motorola (On Semi) parts, and this document shows which are which.
    Enzo's top tip: The MJ15024 and MJ15025 from On Semi will replace most blown TO-3 outputs.
    Peavey schematics
    What's the best way to get Peavey schematics?
      I believe you can call Peavey and ask for them. As far as I know, they give them out freely and also sell spare parts direct.
      (You don't actually have to cross-reference those transistors, you can order replacements from Peavey by the part number that's printed on them.)
        I just emailed their parts department. Seeing as how it's Saturday I'll wait till Monday to call. Thnx
          customerservice@peavey.com good for schematics and other information
          Parts@peavey.com for information and questions only about parts, no orders taken by email for parts. They will take schematic orders by email. Customer service is usually faster.
          Phone call to parts at Peavey - ordering parts.
          Of course all the departments take phone calls if you prefer over email.
            Peavey replacement board for TL604
            This is the sheet Peavey send with the TL604 adapter board plus some
            pics of the real McCoy..
            TL-604 SN-99661 SPECIAL HANDLING 70400604 CMOS
            Enzo Quote
            70400604 is just PVs part number for the TL604. SN99661 is also just a house number for the TL604. They are the same.
            Texas Instrument quit making the TL604 a long time ago, but PV had used tons of them in their designs over the years. When stocks finally ran out, PV had to do something. This is what I absolutely love about PV. Rather than tell us that the part was no longer available, they made a work around. They made a little board with a couple small components on it, and 8 legs sticking down. This subassembly fits where the TL604 used to be. They sell it at reasonable cost, and those 20 year old amps will now be running anouther 20 years.
            Thought it may be useful
              Thats a great table, thanks a lot.
                Peavey-TL-604-Adapter.pdf
                Enzo Quote
                  And as a bonus, you have available 3 unused switches.
                    Some Peavey Footswitch Info
                    Well here is some older footswitch info from Peavey perhaps a better bonus JPB (3 years later)?
                    When I found it couldn't resist posting here. And some more from the helpful Peavey forum thanks to
                    Roger Crimm at Peavey Customer Service
                    Pin configurations of some DIN connectors on Peaveys.
                    On the 7 pin connector (looking from the solder side on the connector) the pins are numbered starting at top right (one o'clock position).
                    5150 II/6505 Plus
                    Pin 1. +17VDC supply to pedal
                    Pin 2. not used
                    Pin 3 Ground this pin to detect the footswitch.
                    Pin 4 Ground
                    Pin 5 Activates the crunch function of the clean channel when grounded.
                    Pin 6 Turns the EFX loop on when grounded
                    Pin 7 Selects between the clean and lead channels( Lead when grounded).
                    Triple XXX/JSX/3120/Triple XXX II
                    Pin 2. not used
                    Pin 3. Ground this pin to detect footswitch
                    Pin 4. Ground/Common
                    Pin 5. Clean/Bypass
                    Pin 6. Ultra/Crunch
                    Pin 7. Effects
                    Ultra Plus/Ultra 60/Ultra 120
                    Pin 1. Bypass/Clean LED on footswitch
                    Pin 2. Reverb Led
                    Pin 3. Ultra/Crunch LED on footswitch
                    Pin 5. Clean/Bypass
                    Pin 6. Reverb
                    Pin 7. Ultra/Crunch
                    XXL
                    Pin 1. Bypass/Clean
                    Pin 2. Reverb Led
                    Pin 3. Ground this pin to detect the footswitch
                    Pin 5. Leds (not used)
                    Pin 6. Effects Loop
                    Pin 7. Ultra/Crunch
                      Transistores Peavey
                      https://www.scribd.com/doc/202686560/Transistores-PEAVEY
                      It's All Over Now
                        This schematic is behind a pay wall. Can it be posted elsewhere by someone who has access?
                          WHAT schematic is behind a paywall? Any Peavey schematic can be had for free by contacting customer service at Peavey. That includes the semiconductor cross reference.
                            Here is the cross reference document: PV Semi Cross Ref 2009.pdf
                              Download the schematics is free, but portal requires prior registration.
                              Registration is free.
                              It's All Over Now
