Marshall 2205 Solid State Slave Head
  • Marshall 2205 Solid State Slave Head
    Bit of a weird one this. Its solid state, definitely labelled 2205. From the trim I'd say mid 70s.
    Anyone got a schematic? Looks like a pretty uncontroversial transistor/op amp design.
    Marshall Amps Info & Schematics
    Look at the 5210 model schematic, see if that is the one.
    Page #1 of the manual lists a 2205. http://www.drtube.com/schematics/mar...-sc-manual.pdf
      2205 schematics that I have relate to JCM800 tube amp, not to transistor/opamp design.
        Yes I'm familiar with the 2205 JCM800 valve design - thats why i said it was weird.
        A bit of poking around on the net shows that this one was introduced in the mid 70s - only lasted for a year or so - and the model number was reused for the JCM800. It appears to be the same as the power amp section of the 2098 Solid State JMP.
          On the first page is written:
          "2205_________50 watt Split Channel Valve"
          In other words, if model is 2205, the amp is valve.
            I'm afraid you're mistaken. The transistor 2205 is mentioned on P.146
            of The Illustrated History Of Marshall:
            Amazon.com: A History of Marshall The Illustrated Story Of The Sound Of Rock (9780793525096): Michael Doyle: Books
              Big problem is, Marshall *does* reuse model numbers, in absolutely unrelated products.
              The 2205 in that user manual gets paired with the 5210 which is *definitely* a transistor amp.
