Hi all,
a friend just brought in a Randall RG75 (hybrid 75W combo)....
I realized I had quite a few choices :
1 - tell my friend to start running 'cause I don't like shooting at still targets.
2 - dump both (friend and amp) straight into the closest dumpster.
3 - breathe, count to ten, calm down and tell the friend I'll try to help him.
What's your guess about what I did?
If you answer is "3", you nailed it! (quite easy, huh?)
(did I really have much of a choice? After all, "that's what friends are for...")
...So....the thing is now on the bench, and it took me only a few minutes to find out that the PT's primary is fried. Quite strange, as the PT is supposed to have a "built in thermal fuse", which doesn't seem to have worked at all. The 1.6 AT(ime lag) mains fuse blew, but it gave the PT enough time to go south....
The PT is labeled "RG75G323050 FEDERAL BUILT IN THERMAL FUSE".
I haven't managed to find a schematic (even the PT specs would be enough, as the rest of the amp seems to be OK), is there anybody out there that has it?
I have thought about rewinding the d@mn thing already, but I'll keep this as an "extreme resource", 'cause, honestly, I'd rather save myself the hassle if I can.
TIA
Best regards
Bob
TIA
Best regards
Bob
