TC booster+ schematic?
  • TC booster+ schematic?
    Hi all,
    I`ve got a TC booster+ line driver/distortion pedal on my bench. The boost function works, the distortion does not.
    There are two 14-pin ICs inside with the numbers sanded off, and no, they are not the usual quad opamps.
    Any help?
    TIA
    Albert
    TC Boost Schematic
    IC 1 looks like an opamp. (Selected).
    IC 2 is some kind of P channel/ N channel thing.
    Here is the schematic & IC datsheets.
      Thank you very much!
      So one of them IS a quad opamp. Somehow I had a different layout in mind when measuring voltages.
      I guess sanding the letters off gives some magic mojo...
      Cheers,
      Albert
        Hi
        Is it possible to repost this Information as I have a unit that no longer switches.
        Many thanks
        John G
          TC Boost Schematic
          Here you go.
            Hi,
            Thank you very much reposting the files.
            Much appreciated.
            Cheers,
            John
              Thanks very much for posting that file. My BLD has recently stopped working; needs an IC; now I know which one!
                Hello guys, any chance to get the schematics too ? The attachments are not working. Thank you
                  The schematics were re-posted as a ZIP file in post #5 of this thread.
                    We had a problem some years back and many files and attachments were lost. Even with that being the case it's still best to post any schematic request independently on this "schematic requests" forum rather than tack on the end of a necrothread.
