have a mixer with bad smps. not under warranty
unit was doa with couple blown traces on ac neutral line and ground. looks like some plugged into reversed line voltage (neutral side blown).
i changed out defective (shorted) rectifiers, bridge rectifier and rf line filter coil. also replaced the multipin smps driver ic, opto ic, 451 transistor. regulators on the sec side are all fine. components from mouser.
unit comes on now, but pulsates. leds, etc all flash when powerd on.
there are small sm resistors that might be open near the optical fb chip, but i dont know the values. they have flash burns from where the foil pads were damaged. there was one shorted hr303 diode on the secondary of the smps, i changed all four to be safe
i can do smps repair but i need relavant values to know these small smd resistors etc.
any help is appreciated! thank you much
email to: dbs4568 at gmail dot com if you can please
