Whenever I turned on phantom power, and raised Channel fader up, would hear a low screech, even no mic hooked up.
Turn off phantom power, no screech. Just thought st. wrong around phantom power circuit
It happens on all the channels?
There are electrolytic capacitors on every input to stop the phantom voltage from getting in to the amplifier circuits.
If it happens on all the channels then the problem is most likely in the phantom circuit.
Check the phantom supply for ripple.
Excess ripple on the supply will come through each channels blocking cap.
Thanks Jazz, I replaced new C27 and C41. No more screech noise
By the way, anybody knows which rack mount kit from current models will fit this mixer Powerstation 600? I found no part No in service manual for rack mount
hey liam, i have the same mixer, Spirit power station600 and was wondering if you could send me the scehematic? my email is cfbutler@nl.rogers.com. it would be greatly appreciated! I'm having troble with the right channel , low volume, the channel works but very low volume? any ideas?
