Eden WT405 Warm Trim Poti broken! Looking for Schematics
  • Eden WT405 Warm Trim Poti broken! Looking for Schematics
    I need the kapacity of the Trim-Poti! Thx for your Help!
    Greets from Germany, Hanover
    Contact Eden.
    Here is there support EMail address.
    amp.support@usmusiccorp.com <amp.support@usmusiccorp.com>
      Guten Tag
      These may help.
      I dont know if the trimpot is in the preamp or pwoeramp, but if it is a DC offset or bias adjustment pot, the values shoudl be similar between different amp models.
      Power Amp bias pot is 1k
      Hope this helps
        I believe the WT405 is different.
        It actually has a "Warm" trimpot.
        Having never encountered one I had to Google it.
        Get this.
        There is a small hole in the front panel that allows you to access the "Warm" trimpot, with a screwdriver.
        (just the thing you want to give a guitar player
        My take is that it was a crappy trimpot (by definition it is not utilized a lot) that just got abused & broke.
          Get this.
          Here the needed schematic is attached.
          Models WT330, WT390 and WT405 are schematically identical,
          excluding different power transformers.
          The “warm trim” potentiometer is TR2 (10K) on page 2 named "OD Trim".
          Good luck,
            hello friends
            can send me the scheme
              Here it is.
                Thank you friend
                  Eden, if there is an issue its likely the low voltage supply or a failed/failing pot.
