I have a Crate GX-130c and there are two 120ohm 10 watt wire wounds that are building up a lot of heat. This amp is from 1992 and it actually has no labeling of internal components. So, I was gonna ask for a schematic but that seems pointless in some way now. I will try to study the traces and test components for their proper values to see what is causing the problem. With wire wound resistors can they be soldered in either direction in a circuit?
There is a trace that leads right to the negative lead on one of the four 50v capacitors.
Here is a file that show the mainboard
or inverted is a bit easier to read certain things
