Line 6 Spider Valve 212 schematic
    Hi Mozwell, any chance you still have those Line 6 Spider 212.pdf ?
    Cheers, Brian
      Cheers, Brian
      This is in the second link I posted. spidere 212 service manual. But you should clarify what you want.. Original post was for Spider Valve, The schematic in second post is for a solid state amp.
      nosaj
      http://bee.mif.pg.gda.pl/ciasteczkow...ice_Manual.pdf
        Enjoy
          The link comes up dead for me?
            lets try a zip file.....
              Mine does not it opens up in a pdf.
              nosaj
                The zip in post #20 is working.
                  Can you send me the Line 6 Spider Valve 212 schematic. Do you have the service manual?
                      https://www.manualslib.com/manual/83...ve.html#manual
                        I have that one thanks. The 212 is different from the hd100. If you run across one for the 212 send or post.
                        Thanks
                        • #27
                          Thanks
                          The link in post 20 works and is the 212, just downloaded and verified.
                          nosaj
                          • #28
                            Thanks
                            Eveidently the hd100 and sv212 share something since that service manual list biasing for the 212.
                            spider valve hd100 4 output tubes spider valve 212 2 output tubes.
                            nosaj
