Fender Hot Rod
  • Fender Hot Rod
    Hoping someone has a schem for a Fender Hot Rod. The customer just brought the chassis to the store and I didnt get a chance to ask him if it was a DeVille or Deluxe (yes I know I could call him). Anyway the PC board is a 2004 and doesn't have a "More Drive" selector on the panel.
    I am going out on a limb here, but I bet you don;t have a Hot Rod DeVille (or Deluxe). I am betting you have a Blues DeVille (reissue) or Blues Deluxe (reissue)
    Try this on for size.
      You're right as usual. I called the customer. The amp was riding in the front seat with no seat belt and of course he had to make a quick stop and the amp slammed into the dashboard. He said the amp worked fine through one gig but later developed an issue with the overdrive channel. The clean channel works fine but the overdrive channel is intermittent. The amp did repeat the same problem on my bench but after a while it wouldn't mess up anymore. Very frustrating. Thanks for the help Enzo.
        Well, there's always the Enzo Whack. Hit the thing with your fist or a rubber mallet.
        My spider sense says look for a control with the back pushed out some.
