Elk Viking 50 Schematic
  • Elk Viking 50 Schematic
    Hello,
    I've got an Elk Viking 50 head that has a pair of el34 power tubes, solid state rectifier, 3-12AX7's, a 12AY7, and 6AQ8. At least that is what came in the amp.
    Does anyone have an idea as to where I might find a schematic?
    Thanks for any help.
    Dave
    these may be close enough for you....
    if not, they are here for posterity....
      the tube line up in these two isn't the same, I guess I am on my own on this one. Thanks for the help!
        after replacing all the original oil filled caps which I suspected and being bad, a handful of 50mfd x 6.3v electrolytics and resoldering some suspect connections the amp still only makes a tinny sound. my last resort was to turn off the amp and flip the voltage select switch on the back from 117v to 110v. As I brought the amp off standby it sprung to life with plenty of guts and bite. In researching Elk amps I noticed some had this voltage selector switch which went from 220v to 110v, this seemed to make sense but my amp was labeled 110v/117v with the 117v label not looking stock but that was what I thought I should have it set to. Anyway, it is working and now I will play it thru a 4 ohm load in a 2x12 cabinet to see how she sounds.
        I'm still scratching my head as the voltages at the tubes and cap cans seemed to be in the general range of acceptability.
        Dave
