LIne 6 Spider IV 30 Schematic request
  • LIne 6 Spider IV 30 Schematic request
    One of these came in the shop with a blown fuse. Replaced the fuse and then got a loud hum. About 2 minutes into tracing the hum, the switching regulator incinerated itself. If I can get a schematic I may consider fixing it.
    Thanks,
    CJ
    All I have is the 15 watter.
    Maybe it is close enough.
      Here it is.
      Good luck,
        Way to go.
        Thanks.( From me & all the techs who have to fight this company)
          Schematic links seem to be broken. I get the feeling that Line6 schematics may have been deleted due to pressure from the manufacturer. Is this the case? Thanks.
            The site had a major loss of uploaded files.
            Which one do you need?
              Thanks for the quick reply and information!
              Ideally, I'm looking for both the Spider III 30 and Spider IV 30.
                Here they are.
                There is also a Spider IV 1508 and Spider IV 75-120-150-H150.
                Good luck.
                  Here is the Spider IV 3012.
                    Thanks much to Zanzoon and Jazz P Bass!
                    Gary
                      Hi, the link seems dead. Could you please re-post. Many thanks. Joe
                        I reposted the file.
                        http://music-electronics-forum.com/a...ematic-bom.pdf
                          Thanks for the quick reply. I have been lucky enough to fix mine, without the schematics - cheaply too :-)
                          My fuse holder had broken and was not making good contact. I had checked the fuse (which was fine) but finally checked the fuse holder and found the problem. $1.25 later and all's good.
                            Not sure if this is worth anything, but rumor has it that Yamaha has bought out Line 6.....
                              Hello Zanzoon,
                              Looking for the schematic for the Spider III 150? Would you happen to have it? It is different to the HD75 you posted here?
                              Joe
