Eden WTX-260 Schematic Needed
  • Eden WTX-260 Schematic Needed
    Hi, looking for an Eden WTX-260 schematic. Appreciate any help with locating one.
    Thanks, Chuck
    Thanks, Chuck
    Here it is.
      Thanks doctor!
        Isn't this Forum (& the Internet) just great?
        Thanks Doc.
          Hi Doctor
          do you have the power amp sch for this amp
            You noticed that also, I see.
              I have not additional schematics related to the WTX-260 model,
              but I will try to clarify this issue.
                I think that you don't have it. The power amp (most probably integrated with switching power supply) is a module from Bang&Olufsen. It's funny that class-D power amp is described as: "Powered by a unique Analog Switching Amplifier" on Eden's web site. What exactly is "analog switching amp"? Here is some more info: Eden WTX-260 Bass Amplifier: Good things come in small packages . They also use some mysterious Golden Ear chip - has anyone seen it?
                Mark
                  Originally posted by doctor View Post
                  Here it is.
                  please you can reupload the attached Files? not work
                  thanks
                    Various eden schematics attached
                      one question for you:
                      in the schematic of wtx260, what function does the VR7 trim pot?? thank you all
                        I believe VR7 on sheet 3 of the preamp sets the limiter threshold.
                          Thanks for the reply! Last question: what is the switch that turns off the compressor?K1 or S2?
                          I want to mod my wtx264 that has the same cirtuit of wtx260. Thanks for the patience
                            K means relay, S means switch.
                              S2 is the compressor defeat.
