Need Schematic for Line6 Spider Valve 212
  • Need Schematic for Line6 Spider Valve 212
    I have a Spider Valve 212 in my shop and need the power amp board schematic. I know it's been posted before but since the links are all bad I'm requesting it again. If anyone can post or send via email I'd really appreciate it.
    Hello, I would like to join in on the request for Line6 Spider Valve 212 schematic and/or service manual.
    I have found a service manual for the Spider 212, but no luck on the Spider Valve 212. I also would be very grateful if anyone could share it.
    Thanks.
      Thanks.
      Here is the power amp schematic.
        Thanks!
          Thank you very much!
            Thanks again for the power amp schematic, but it seems that the problem with this unit lies within or near the following logic board:
            A15: SV MAIN
            #35-00-0250
            Rev A 8June2007
            If you or anyone else has a schematic of the digital/logic part of the Spider Valve 212 or even a complete service manual I would be most thankful.
              I need a schematic for Line6 spider valve 212
              Please send me a schematic for a Line 6 spider valve 212 and service manual. Need to fix this amp.
                This should be it.
                https://www.manualslib.com/manual/83...ve.html#manual
                  Thanks I can use this
                    Too funny this is the same one as the other thread. Same service manual .
                    nosaj
                      Yeah, this is exactly where I pulled the link for the other thread from.
