Fender FM 100H Schematic?
  • Fender FM 100H Schematic?
    Took the chassis out to clean the controls--noisy and intermittent. When I reinstalled the chassis, DC on the speaker output. I guess I damaged the circuit board somehow. The chassis is pretty thin metal. The outputs and drivers are marked with standard part numbers, so I know what to get, but would love to have the schematic to carefully check through the circuit. This schematic is not on the Fender web page that they maintain of schematics.
    Thanks in advance!
    Did you try contacting Fender to see if they would send you the schematic? Also, how similar is the FM212 schematic to this amp? Not the same, but may have similarities. <<< Just curious how these amps might differ...
    Also, how much DC was measured on the output?
