Mosvalve RT-2100 Schematic Request
    Full schematic would help.
      See post #4.
        See post #4.
        Translation: "Pay attention, Dude".
          Originally posted by Spank94 View Post
          Oh, thank you very much. Good point to check the other jacks. The 'receive' jack is as well a bit challenging to understand :-).
          I really dare to ask another question about this schematic, but if someone still like to solve a schematic challenge:
          How can this "Clean Green" ever light up? :
          And on this same schematic screen shot.You see a kind of integrator amp (Used to switch channel, therefore CH input on the left). But at the opamp positiv terminal you always have the diode forward voltage (~570mV if using a 1N4148) and on the negative terminal you will always have B- plus forward voltage. Independent of CH input (which is 0V or twice diode forward voltage).
          The output of the amp will always be negative rail.
          Unless I'm missing something, the diagram has to have an error. With the "blocking" diode in front of the LED, I don't see how there could ever be negative voltage on the LED cathode to make it light. I get it up to post comparator, but after that, it doesn't make sense. I suspect either the LED or the diode in front of it is drawn incorrectly. You should be able to find out more with your meter measuring voltages.
          holiganbet betturkey
