This is a low end powered mixer with a built in cd player. Preamp out is ok but nothing from power amp. Nothing looks burned and transistors test ok in circuit. A scnematic would help. Thanks.
Need schematic for Alesis gigamix 4 cd
Originally posted by fredcapo View PostThis is a low end powered mixer with a built in cd player. Preamp out is ok but nothing from power amp. Nothing looks burned and transistors test ok in circuit. A scnematic would help. Thanks.Attached Files
Thanks doc.
To follow-up, in general, what is the prevailing wisdom as to repairing equipment of this type? This unit has a number of smaller circuit boards. Are boards typically available from the manufacturer at a reasonable cost to faciltate repair?
Thanks for the info. I am doing this work for a music store that may have a relationship with Alesis...I will need complete schematic at least to go forward on this.
Anyway when I made some initial measurements, I get +/- 61 vdc on the collectors of the output transistors, where the rails are shown as +/- 48 on the schematic, 0 vdc on base and emitter, AND the mother of all arcs when I discharge the rails to ground after powering off.
So, is the overvoltage just a symptom of nothing conducting...or other problem
and why are caps not bleeding-off... (same reason?)
Thanks.
alesis
Originally posted by doctor View PostIn what boards you have additional problems?
Layout of what boards you really need?
Contacted Alesis and they refused to supply a schematic. The mixer was sent to us for repair with other equipment by a very large school district here in Morris County. We made a point of suggesting to them that they refrain from any future purchase of Alesis equipment, except we didn't exactly use the word equipment...
