Blackstar HT1B see no filament on tubes, cd input seems to work. Need a schematic thanks.
need schematic for Blackstar HT 1B
you can follow the filament without a schematic
but make sure the power is unplugged
open it and see if there is a filament fuse
many of the new amps have a filament fuse
between pins 4-5 and 9 on a preamp tube, you will usually see 6.3 volts AC
sometimes the filament is powered by DC on the same pins.
If you are unfamiliar with measuring, have a tech do it for you.Last edited by soundguruman; 01-24-2014, 02:32 AM.
