I now get a hum at TP8 (pin 7) with the probe and a bit of the 1K signal mixed with hum at pin 6. I can hear the tone faintly when injecting it at J14
Crate GX140C schematic needed
Originally posted by Enzo View PostIt wasn't going to have been the source of the DC, but it also didn;t belong.
I am still with my suggestions of post #27.
Find out if you need it, just remove Q25. Does the amp now work? If not, the IC is probably bad, and if it does, then leave it out until you can get a new one, the amp will work fine without Q25.
The type of JFET is not at all critical, but be aware the legs of a sub may not be in the same order, you'd have to determine that and install a sub part so the legs went into the proper holes on the board.Education is what you're left with after you have forgotten what you have learned.
OK, done deal. Boy, you fellows sure took me to school on this one. I feel like I've just come up on the semester break. Thanks all. Thank g-one for making me make sense of the process.
Enzo, I only replaced the bad parts: R42 (22 ohm), Q8 (j112), IC4 (TL072), and IC3 (TL072). I put Q25 back where it belonged.
