Looking for a scem for the modern Fender Deluxe Reverb combo . Not sure how different it is from the old one , but... anyone have one ?
MODERN deluxe reverb
Some may be 65 Deluxe Reverb Reissue.
That's what I have been seeing around, as far as new deluxi...
fender 65 deluxe.pdf
I apologize if this PDF does not attach correctly, it happens sometimes.
Yeah I can't read it.
PM your e mail to me and I will try to email it to you instead of posting it.
I think Valvehead refers to this :-Fender '68 Custom Deluxe Reverb 1x12" 22-Watt Tube Combo
I've had some inquiries locally to how it sounds and I haven't a clue...
Some specs
"Unique Features: Modified Deluxe Reverb all-tube circuitry, shared reverb and tremolo on both channels, “Vintage” channel for traditional silverface operation, modified “Custom” channel with Bassman tone stack, reduced negative feedback for greater touch sensitivity, hand-wired tube sockets, custom-made Schumacher transformers (like the originals), genuine Fender tube-driven spring reverb, genuine Fender tube-driven tremolo (“vibrato”), 1968-style Silverface aluminum trim around silver-turquoise grille cloth, fitted amplifier cover included."
Seems like Fender have done the mods so we don't have to advise..... Haven't found the schematic but if we put 2 and 2 together....
If it's from 2002, it won't be the 68 Custom, they just came out last year.
It will be the 65 Deluxe reissue, schematic available from Fender here:
http://support.fender.com/schematics..._schematic.pdfOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
There are really just 3 things that I have seen go wrong with 65 reissue:
1. A bad output tube socket
2. Bad screen grid resistors (470 ohm 1 watt) change the output tubes, in that case...
3. The speaker plug, (molded plastic plug on speaker wire) which connects amp to speakers, goes bad. Replace w/ metal 90 degree switchcraft plug.
Originally posted by soundguruman View PostThere are really just 3 things that I have seen go wrong with 65 reissue:
One DRRI that had gone on tour across the country came in with an OPT that had fallen off due to metal fatigue of the mounting flanges.
