Please help - need schematic for a Peavey Transflex pro 212 combo
  • Please help - need schematic for a Peavey Transflex pro 212 combo
    Please help - need schematic for a Peavey Transflex pro 212 combo.
    The internal battery has leaked and corroded through some tracks . i've cleaned up the board and should be able to fix it but need a schematic to figure what connects were??
    Any help would be much apreciated
    Call peavey they will email it to you
    nosaj
      I've tried emailing them here in the UK but with no response?? I'll give it another go this week calling them. Not sure where your based, are you referring to calling them in the UK or US?
      Thanks
        Contact the factory, if you ar in the UK, email them
        customerservice@peavey.com
        No point in calling all the way to the USA, but a phone call to Peavey-UK will be more likely to get results than emails.
          Nowadays with Skype and VoIP, it is essentially free, to call around the world. He will get better results talking to the factory. Peavey's admired US customer service ends at the water's edge
            I looked at one of these a few months ago. Battery leaked and caused some corrosion.
            I cleaned it up and soldered wires in all the feed-thru holes. It worked for a while then
            started flashing "DSP ERROR" on the display. I tried factory reset and whatever else I
            could think of. Nothing worked. It was taking too much time so I gave up on it.
            Still waiting for my customer to pick it up.
            Here is the schematic. Good luck.
            Doug
            http://music-electronics-forum.com/a...1&d=1398099831
              Excellent thanks all & especially Doug (dmeek) for schematic , luckily the battery hasn't leaked to much so i may get away with it.
              Thanks again all.
                I believe Baking Soda will neutralize the acid.
