Wanted DOD effects pedal schematics
  • Wanted DOD effects pedal schematics
    Anyone have a good free site for downloading DOD pedal effects schematics? I'm looking for the following: FX 66 Flashback Fuzz, FX20B Stereo Phasor, FX69 Grunge(I believe this is the 1st version - not 69B). Thanks to all for any help.
    Last edited by bobsamps; 06-19-2014, 02:25 PM. Reason: spelled pedal wrong in title
    I found some here. http://www.freeinfosociety.com/site.php?postnum=2405
      The fx66 is here:
      http://www.schematicsunlimited.com/d/dod
        No schematics, but lots of layouts here. Guitar FX Layouts: DOD
        It's not microphonic - it's undocumented reverb.
          Thanks but I am unable to download as I am at a public library. Wouldn't want extra download cookies and whatever anyways but thanks the link is here.
            You could just browse the images from a google image search for "Dod schematics" in the library. Good luck.
              Links to DOD schematics
              http://elektrotanya.com/?q=showresult&what=dod&kategoria=audio
              http://www.americaspedal.net/fxlit/cat/
              http://www.americaspedal.net/fx20b/
              FX20B Stereo Phasor
              It's All Over Now
                If you still do not have a certain schematics, let me know.
                  Thanks you all have been very helpful. One bummer I have found with a pedal, the Flashback fuzz, is that the pushbutton mechanics were broken. The plastic architecture was defective. So I am contemplating placing the unit into a new box and wiring a true bypass to the circuit. Then again I am also working on a distortion of my design which I hope will suffice my search for better design.
                    *ping Doctor*
                    Hey Doc, if I can take you up on this!
                    I've got a FX-65 (v1) pedal from '85 that I haven't been able to find the proper schem for, for the life of me. (If you have a full svc.manual even better!)
                    This one has the additional green LED on the pcb (in addition to the red one that's used as an on/off indicator visibly mounted to the chassis) only TWO transistors, two internal trimpots, 2 4148-type (signal) diodes, and what looks like a 4001-type in battery protection.
                    (For reference)
                    v1 2-trans., LED on R, 2 sig.diode, 2 trimpots center (ca.85)
                    v2 6-trans., LED on L, 1 sig.diode, 2 trimpots moved (ca.87)
                    v3 6-trans., NO LED, 1 trimpot (bias) (ca.88)
                    v4 (like v3) screenprinted, green caps, rev.k pcb (ca.88)
                    v5 (real oddball) screenprinted, yellow caps, only 2 (new) alpha pots (non-ECI) found housed in FX-60 chassis rev.m pcb (ca.91)
                    (appears to be factory 1-ohm jumper in place of 3rd pot). Factory repair/replacement perhaps?
                    Thanks in advance for checking!
                    -Rob
                    Credit to americaspedal.net for pics of rev1 and rev3 photos!
                    Start simple...then go deep!
                    "EL84's are the bitches of guitar amp design." Chuck H
                    "How could they know back in 1980-whatever that there'd come a time when it was easier to find the wreck of the Titanic than find another SAD1024?" -Mark Hammer
                      (For reference)
                      [ATTACH=CONFIG]29956[/ATTACH]
                      [ATTACH=CONFIG]29955[/ATTACH]
                      [ATTACH=CONFIG]29954[/ATTACH]
                      [ATTACH=CONFIG]29957[/ATTACH]
                      [ATTACH=CONFIG]29958[/ATTACH]
                      -Rob
                      DOD did not provide service manual in the usual sense, there are schematics only.
                      For several multi-effects processors only adjustment procedure is supplied in addition to schematics.
                      For the FX-65 Stereo Chorus I have only one schematic.
                        Good to know, and MUCH appreciated!
                        Thanks again sir!
                        Edit: Looks like this one should be good to go for v3/v4! (6-transistors, 1-4148 diode, single 5k bias trimpot) It's probably fine for v5 as well, but I'm going to err on the side of caution as of just yet.
                        Again, I appreciate you taking the time and effort Doc!
                        Just noting it so whomever sees this thread in the future would know!
