Line Voltage Select done with Fuse Holder
The IEC Power Connector/Fuse module on your rear panel is of the type that also functions as the AC Mains Voltage Select. The AC Mains wiring on both your amp and mine are the same on that IEC/Fuse module, as well as the AC Mains Switch. To change to 120VAC, you pop it out and rotate it, while changing the Fuse Value. T4A GMC size (5 x 20mm) would be what you'd want. Chances are there is a T2A fuse installed.
I just re-read your last post, and see you are in a 240V country (Australia), so your amp IS wired correctly for 240V, based on the Selection mark on the voltage rating to the left of the Mains connector/fuse holder. I can confirm the WHT wire (AC Mains N terminal) is adjacent to the BLK wire (AC Mains L terminal) on the Mains/Fuse module. Your YEL wire which was unplugged from the AC Mains/Fuse module IS connected correctly, so your guess was correct.
Eden 4012.038_na320.pdf
On page 7 in the owner's manual I've attached (NC320 Bass Amp, but will suffice for your NC250 regarding AC Mains Fusing & Voltage Selection), the instructions on selecting Line Voltage are shown.
Originally posted by Tim81
View Post
