Does anyone have a schematic for a Mackie SRM450 ver. 2?
Mackie SRM450
Mackie SRM450 V2 Schematic
Here you go.
Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
Here is a photo of the PC board. It seems it was repaired previously (because of the same reason - failed PCF circuit). I found out that the core of the PCF coil is loose. Can this be a reason for the failure? The core can be moved about 2 mm. I assume that the core shouldn't move. Maybe it was glued initially?
Mark
I've got a couple of these, with damage in the same area.
My hypothesis is that the ferrite bead/choke that is on the cables going to the speakers gets loose and when you move the speaker around (especially when it has power applied) it bangs against things shorting them out, or at least physically bashing the components apart.
