Hiwatt hi gain 100 footswitch schematic
  • Hiwatt hi gain 100 footswitch schematic
    Hi all,
    Trying to find a schematic for a Hiwatt hi gain 100 footswitch . Any wiring info or photos would be great.
    Thanks
    Cannot find the schematic for the 100.
    I have found the 50.
    On that amp, the FootSwitch jack is 1/4" plug, T/R/S.
    So use two stomp switches with one wired Tip to Sleeve & the other wired Ring to Sleeve.
    hiwatt_hi-gain_50_Ft Sw.pdf
      Excellent thanks Jass P Bass - i'll get that built this weekend.
      Also there is a second footswitch jack 1/4" on the back of the amp that's for the reverb & loop ??
      Bye the way where did you find the schematic? as I've been looking for a while now. (Hiwatt info seem's really hard to find)
        Are you planning on using led's ?
          Hi,
          Yes i'd like to use the leds but not an issue if a cant.
          I've manage to get hold of a old Peavey 4 button footswitch fairly cheap (looks just like yours - but different text). So i will have a go at rewiring that, only thing it has 5 pin DIN on it so will change for 2 stereo 1/4" jacks
            Sorry to revive an old thread but...
            A schematic of the 50W hi gain Hiwatt amp can be found here:
            HIWATT HI-GAIN 50 COMBO SCH Service Manual free download, schematics, eeprom, repair info for electronics
            I thought I post it here because I was looking for it and found this post without resolution.
