Behringer PMP4000
  • Behringer PMP4000
    Does anyone have a schematic for a Behringer PMP4000 powered mixer?
    The 1000, the 4000 & the 6000 are supposed to be the same.
    Here is the 6000.
    behringer_pmp6000_sch.zip
      Here is the 6000.[ATTACH]33611[/ATTACH]
      Eh... yeah, kind of. It seems that the different mixer boards, (the big one) have all different ref des for each model so tracing and locating components is kind of a problem. Sure the board is laid out logically but some areas are more gray than I can work with, like the monitor and effects chains. Specifically I'm looking for the monitor 1 mute transistor (I suspect it's shorted) but I don't see any apparent transistors in that area or any other area for that matter and the reference designators are all over the place, not like on the 6000 schematic. I need a 4000 schematic too.
      ... That's $1.00 for the chalk mark and $49,999.00 for knowing where to put it!
        If anyone happens across this schematic. I would appreciate a copy too. I know the SMPSU29 power supply is the same as the 6000. but there are areas that as stated are a little grey.
        Thanks
        What light reveals that, which is hidden within the shadows of the mind?
