New Month We are at $74.35 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
Here is the link. Check your bias supply and all other voltages at the tube pins. Roughly 460v on pin3, a few less on pin 4 and about -45v on pin 5. Unless you have specific voltages, these should get you close.http://el34world.com/charts/Schemati...00w_dsl100.pdf I guess I should make sure you are OK with working around high voltages.
There are quite a few versions of that schematic, see if the board has an issue/revision # marked on it. The latest version schematic I've seen for the power amp is issue 7. Some of the component numbers will be different for the different versions.
