Gibson G70
  • Gibson G70
    Hey Folks ! Anyone know where I can find a Gibson G70 schematic/layout ?
    Thanks !
    Here's the annotated power amp.
    Can search for the preamp if you need it.
      Um... shouldn't Q6 be an NPN?
      And are they not darlingtons?
        Thanks Juan ! I'll take all I can find. I'm coming up empty.
          Hey !!! this is the official GIBSON schematic!!!!!!
          Don't tell me you know more than them !!!!
          Just answer: did Eric Clapton and Jimi Page use a Gibson guitar or an Enzo guitar , huh ?????? <--typical TGP/MyLP/Harmony Central/etc. argument
          Q3 , Q4 , and Q6 are NPN .
          MJE1102/1092 are Darlingtons (notice the 1000/1200mV BE bias I expect to find there) and to boot are way underpowered for a 70W amp : 5A max current , "70W" , in that tiny smaller than TO220 case, like typical Peavey drivers .
          They were notoriously unreliable (I wonder why ) and upgraded 3 times.
          MJE1102 pdf, MJE1102 description, MJE1102 datasheets, MJE1102 view ::: ALLDATASHEET :::
          I suggest TIP142/147 there, but pinout will no match, check both datasheets.
          I posted what I found first, there's an old thread here, also search for other Gibson amps, there's one called something like G50/60/80 somewhere in MEF, all preamps were basically the same.
            Thanks for the info. I'm trying to find out what the values of the two big can caps are ?
              Here's a Gibson G50/60/70/80 schematic, obviously a very different version under the same name.
              It's in SSGuitar
              Login
              Gibson G-80
              As said before, they kept replacing them under warranty, this one is a little stronger, used TIP33 powerhouse transistors .
              Don't know which you actually have, a Darlington or a Discrete one?
              Post a couple pictures.
              For good measure, I'm adding G10/20/30 too so you have all the family.
              By the way, what are you trying to fix?
              PD: that said, yours might be *completely* unrelated
              EDIT: that's the easiest part: 2200x50V or 4700x50V .
              Tne earliest ones used large chassis clamp mounted electrolytics, modern ones will be radials 1/2 (or less) the size, solder their legs where approppriate.
              Unless you want to keep the Mojo and insist on $65 a piece NOS Electrolytics.
              If so, I also have a couple bridges you might interested in, you give me U$5000 in cash, in small denomination unmarked bills and then you can charge toll to cars using it, how's that?
                It's in SSGuitar
                Login
                Gibson G-80
                Thanks Juan ,I'm good on bridges lol
                I'll get some pictures asap.
                  Here are a couple of chassis shots.
                    Ok, then you seem to have the same power amp as the original "orphan/annotated" schematic, because on ther right edge of the first picture I see 2 x TO92 transistors (Q3/Q4?) , a TO220 one (Q5?) , 2 puny small plastic transistors (TO126 case? ... ridiculous) 2 bias diodes clamped to chassis/heatsink and the very old style bias trimmer.
                    I'd replace the power transistors with TIP142/147 without even checking them, go figure.
                    Pay attention to pinout which does NOT match.
                    The preamp might match though:
                    2 DIP ICs
                    2 trimmer pots (reverb & tremolo)
                    5 TO92 transistors
                    1 heatshrinked *lamp*/LDR tremolo roach.
                    Oh well.
                      2 DIP ICs
                      5 TO92 transistors
                      Oh well.
                      Thanks Juan ! I don't have this amp in hand yet. It belongs to my cousin ,and I'm waiting for him to bring it to me. We'll get a parts list together also.
                        2 DIP ICs
                        5 TO92 transistors
                        Oh well.
                        I finally have this amp in hand. Looks like someone tried to mod? ,or repair at one time. Added caps ? Some places you can see were disconnected from the board ,and hardwired. May have to strip all the mods? ,and start over.
                          Could Admin please move this ?
                          Could this thread be moved to repair ,and troubleshooting , or should I start another for repair help ?
                          Thanks !
                            Thanks !
                            No admin here but you could start a new thread at the appropriate spot R&T, & put a link back to this thread for e-z reference. Costs nothin' but a minute of your time.
                              Thanks Leo_Gnardo lol
