macro-tech 3600vz
  • macro-tech 3600vz
    Hi all,
    I've a faulty crown 3600vz with non powering up problem, first left channel went down found shorted to-3 say about 4 and .47 ohm resistors gone.
    fitted new one's in and cold checked between pcb channels no short's found, so fitted it back together and double checked before powering on and the only thing it does is green led's light up but no relay click over? has anyone had the same fault with there crown amp?
    many thanks for now.
    Experience comes with more understanding
    Stating the obvious perhaps, but it's common for the driver parts to get damaged too. Don't plug in a speaker until you know you have it fixed. To get and constructive help you should try and hunt down a set of schematics. There is a service manual out there but it's missing the schematics.
