Hello,
I have a "new" MG100HFX from a deal.
It produce to much hssing when I turn pot volume & Master.
I have just opened and see to PCB (3 parts) AMPLIFIER - DSP+PREAMP - POT&SWITCH FRONT PCB
i have the necessary scope, generator etc. but I need the schematic.
It is more simple to follow the signal from input and try to find where is "the hiss generator".
BE CAREFULL I have found many schematic of MG100HDFX OR RCD etc. but they are not use discrete transistors but TDA7293/94 chip power amplifier for the final part of the amplifier.
On the MG100HFX we find 2SC5200 & 2SA1943 on the final stage.
Potentiometers on face just send command to DSP to adjust the settings There is no analog signal thrue the PCB.
All cables are not shielded from DSP to amplifier PCB ???? !!!!!!!!!!
If any body have a link or the shematic, It will be so great.
Thanks
Steven
Thanks
Steven
