EDIROL UA-25 schematic?
  • EDIROL UA-25 schematic?
    I need a schematic for the EDIROL UA-25.
    There is a problem in the power supply area.
    there is power at the USB connector but not
    at the input of the LT1111 converter(IC35).
    The board is not easy to trace.
    Thanks!
    Highly doubt that you will 'find' a schematic for that unit.
    If the USB jack has power but the LT1111 converter does not, look for a surface mount fuse from the jack to the ic.
    It may be open.
    LT1111 Step Up.pdf
      It may be open.
      [ATTACH]38893[/ATTACH]
      I dont see a fuse but a P-Mosfet 2SJ325
      The gate is not driven. The "on" signal is missing.
      My request at ROLAND service did not lead to a schematic.
      Is Roland especially uncomfortable in that regard?
      Digitech sent me immediately a schematic for a dead Whammy 4 Pedal.
      That was nice.
        Problem solved:
        it was a corrupted driver.
        The driver must work correctly, otherwise the 2 Fets for the power conversion chips
        get no "on" signal. The interface was completely ok though.
