One on the reverb send & one on the return.
The drains went to the grids of the 12AX7 and the sources where at ground.
The return one was shorted gate to drain.
There is a jack on the rear of the amp to turn the reverb on & off.
The ring is at ground & the tip goes to the two jfets gate pins.
Grounding the gate voltage would turn off the reverb.
The hint was that I had no gate voltage (+13.5Vdc) on either jfet or the jack when the reverb was On.
It was 90 ohms from ground because of the D to G short.
