Peavey XR-1200 Schematic
  • Peavey XR-1200 Schematic
    Good day I been trying to download the cs400 pdf, for this PV, but it will not download.
    Any help would be appreciated. Have a couple burnt resistors unable to determine value.
    Thank You in advanced.
    Try this:
    Peavey XR800, XR1200, XR1600 Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
      Thanks for the reply, this one does not have the schematic for the main output transistors and resistor where 10W .33 and 5W 5.6 are located this is the are I'm trying to fix. has a few resistor on boards that need replacing. Unable to determine values. Thanks again..
        Oops! Sorry 'bout that. I didn't know the amp portion was not included. I believe that mixer uses a CS400 amp. You might try seeing if you can find a schematic for that amp. It should be similar enough.
          Thanks for your fast response. It is CS400 and is show in this forum but when trying to download, is not available. Show this message "There was an error opening this document. The root object is missing or invalid."
            The forum server crashed a while back and some of the older uploads are missing.
              Thanks again for fast reply. Any suggestion. I'm trying to get this ready for tomorrow night rehearsal if possible
                I haven't looked at it yet, but you could try this? There are several versions of the CS400, so no guarantees this will be the right one.
                PEAVEY cs400 Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
                  Thank you. This is exactly the one. I had searched but only by xr1200. Great. Will start working on it early in the morning. Thanks again......
