Early Gretsch Super Bass Schematic Needed
  • Early Gretsch Super Bass Schematic Needed
    Hi all,
    I just inherited an early 60's Gretsch Super Bass Combo which is similar to a Gretsch 6157 Head. I'm looking for a schematic for the combo which has a seperate top mounted preamp & bottom mounted power amp. The two are connected by an octal & a 2 pin connector. The 2 speakers connect using the same type 2 pin connector of which one is missing. Any info would be appreciated.
    Drewline
    When was the last time you did something for the first time?
    So you need a two-pin speaker connector?
    A photo would help us identify the connectors you need to mate.
      Here are pictures that I better show the size of this plug & socket.
      In my other post I said that the connector pins remind me of those old polarized cheater cords I used to see in my Father's shop.
      Drewline
        They look like the connections found in old radios for phono/turntable connections.
        Two pins one larger than the other. Similar plugs were made for battery connections on a round bakelite wafer.
        Couldn't find a reference apart from this which probably wont last long as are pictures from ebay.
        I'll attach a picture from there ..
        https://picclick.co.uk/Vintage-Radio...l#&gid=1&pid=3
        Three upper left look similar but are hard to see
        EDIT: I missed the repost in Vintage Amps .... http://music-electronics-forum.com/t44265/
        Last edited by oc disorder; 04-27-2017, 01:52 AM. Reason: answered in Vintage Amps
          Finally got a chance to get back to this old butchered beast. I need to find a schematic to this particular Super Bass which is Model 6154. I have no idea what was done to it in the past. So if anyone might have a schematic I'd appreciate a copy
          Thanks,
          Drewline
