Ok. First one in my shop. Multiple PCBs and lots of molex connectors. Anyone got ahold a schematic for these yet? Treble is acting like a volume. I traced the caps that I see connected to the Treble pot and none of them read dead short.
Fender Bassbreaker 007
Originally posted by lowell View PostOk. First one in my shop. Multiple PCBs and lots of molex connectors. Anyone got ahold a schematic for these yet? Treble is acting like a volume. I traced the caps that I see connected to the Treble pot and none of them read dead short.
Thanks, nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by nosaj View PostGive us some board numbers maybe pull something that way. This is the 7watt?
Thanks, nosaj
Vintage Amps Bulletin Board ? View topic - '59 Bassman Treble down = Volume Up.
Tone controls acting like volumes! Need Help!
Hope they help.
I had to step away for the rest of the day. I couldn't stop thinking about it though, and realized it's gotta be that the mid/bass section isn't passing signal. That'd make the Treble act as a volume since it's the only one passing signal. The amp definitely sounds THIN too. Time to bust out ye ol scope.
But out the ohm meter. From the bottom end of the treble control, what resistance to ground as you rotate the bass and mids controls.Education is what you're left with after you have forgotten what you have learned.
I've seen credible reports of this issue occurring with DRRIs etc; it seems that the pots short somehow and that a squirt of pot cleaner can fix it.
It can't hurt to try it!My band:- http://www.youtube.com/user/RedwingBand
I would suspect contaminants inside the pot, this is not a very old amp, right? Like maybe a tiny flake of metal inside riding in the lubricating goo.
I guess I was wondering, while it works, what range resistance do you see as you turn the bass and mids controls from zero to max while reading the low end of the treble. I am assuming in my head something similar to a zillion other Fender tone stacks.Education is what you're left with after you have forgotten what you have learned.
