Originally posted by bigdrums925
View Post
That could only happen if either the current through Q6 was high or the gain of Q6 was lower than I expect. From post #81 (I assume the supply is 46.6) the drop across R27 is 1v so the current is 1/220 = 4.5mA. Q6 should have an HFE of at least 120 so making the base current 4.5/120 = 37.5uA
Now the current through R25 is 1.7/34 = 50uA, much too close to the base current. This explains why Mark gets a different result from me in the simulation and thanks for the cross check.
In my sim the base current is just 4uA, I bet his is much higher. The basic intention of Q6 is to regulate the idle current with temperature and that is the reason Q6 is thermally coupled to the heatsink. With the values we have here the idle current is going to be affected by HFE variations with temperature (and ageing). We don't know what the designer had in mind. I believe that HFE rises with temperature so the overall effect of this current starved design is that as temperature rises the Vbe lowers and so the collector to emitter voltage follows, also the rising HFE will reduce that voltage even further. This is a good thing so long as there not too much of it and we get crossover distortion. This seems a really cheapskate way of achieving thermal regulation as it's so dependant on transistor characteristics. A better and commonly seen design adds a thermistor this part of the circuit.
I did mention much earlier that the reason for leaving the resistors at 33K was complex....
So, the conclusion is to leave things as they are with 33K resistors for now. Turn the trimmer all the way towards the R25 end and then measure the voltage from Q11 base to Q10 base with no load and no Q10 or Q13 fitted. Repeat with the trimmer all the other way.
Whether we need to change R26 to something smaller depends on the result of this test.
