Peavey 6505+ squeals
  • Peavey 6505+ squeals
    Hello:
    The amp squeals when you use the lead channel.
    If you turn the lead gain (pre control) past 6
    if squeals at about 1KHZ, it sounds like a tone generator.
    It does it with or without an input.
    Hoping someone has had to deal with this problem
    and can save me some troubleshooting time.
    Thanks for any help.
    Try changing preamp tubes, then check filter caps
      I would pull V1 to see if it stops.
      That is The Most Critical tube in the amp.
        I did remove V1 and the squeal stopped but when I subbed in a new tube it came back.
        I also subbed in the other pre-amp tubes but still had the squeal.
        I guess I'll have to check all components in that circuit for defects.
        Thanks everyone for the input.
          That tells you that V1 is involved in the oscillation. Doesn't mean it is at fault, but it is involved.
          Don't assume all problems a a "bad part". A poor ground connection could be the problem, such as a screw on the corner of the board that also serves to ground the circuit to the chassis, that sort of thing.
            I didn't see any ground problems. I spoke with a Peavey technician and he said it might be a normal condition with the gain turned up that high, but it seems to me
            that they wouldn't have engineered it that way.
              it sounds like a positive feedback,due to a bad filter cap,either c35 or c72.
              you can parallel a new one with clip wires,see if it changes
