80s Ampeg V3 MTI model schematic request
  • 80s Ampeg V3 MTI model schematic request
    I've been looking for these extensively.
    I have the V7 schematics, which helps, but would like the V3 MTI made 80s ampeg.
    Steve L posted what appears to be the correct ones on 5/13/2011.
    Enzo has informed me of a server crash which turned them into a tiny white dot.
    The V3 schematics from the 70s is not what I'm looking for.
    Thanks
    Here are the schematics for V3, V5 and V7. These are all 80s models.
    Big thanks to Steve L for sending these to me!!
    The V3 was very hard to find. The V7 schematics are floating around out there, and are the same, in a 100w version.
    If anyone knows the output voltages from the PT in the V3, it would be helpful.
    Thanks, this forum is always the place I find the answers I need!!
      As we had a server 'crash' since these schematics where posted, they are not viewable, as they have the same tag as the 'crashed' file.
      If you compress the files (ie: zip them) they will be viewable from the site.
        Can I just change the file names?
        My phone is not cooperating! I will have to do this later.
          Changing the filename will not help unless you can change the filetype.
          I think if you change any of those from .pdf to .zip, it should work, then we will have to download and change the name back.
          Worth a try anyway, it's something we have never tested.
            Here is a Zip folder with all three schematics V3 V5 V7
            Ampeg v3 v5 v7.zip
