Trace Elliot AH1000-12 schematic needed
  • Trace Elliot AH1000-12 schematic needed
    Hi,
    I've bought a Trace Elliot AH1000-12 with one power amp module blown.
    Is there someone that can share its schematic?
    I would like to repair it, otherwise to substitute it with two class D power amp modules, keeping the power supply as is. Due to the higher efficiency of class d amps, there will be two paths: keep the same output power and make the power supply's life easier, or increase a bit the possible output power. I'd go for the former, as 1000 W are absolutely more than what I'll never use.
    Thank you in advance
    I've found this link: https://elektrotanya.com/trace-ellio.../download.html
    But there's not everything. Has someone ever substitued those power amp modules with something different?
    Thanks!
      If you do not need the full 1000 watt output power, then why do you not simply run the one amplifier at 500 watts?
      I would disconnect any power leads going to the dead module.
Name:	Trace Elliot AH1000-12.jpg
      Edit: have you checked the fuses?
      I had one of these a while back with a 'dead' module and the fault turned out to be the Speakon output connector, not the amp.
        When was yours made?
        Manufacturers keep famous bestselling names but change guts now and then; older ones had Class AB "analog" Lateral MosFet outputs, big heatsinks and heavy power transformers, modern ones use lightweight SMPS and Class D power amps, show your amp guts to be certain.
        Front panel and general cosmetics may be the same.
        No, just one path: same power with colder amp.
        Power supply defines output power, the power amp is just the "faucet" which sends more or less of it to the speakers.
          Thanks for the feedback Jazz P Bass. I’m sure it’s dead because I bought from a guy who tried to fix it, and almost destroyed that module. I would prefer to find two class d substitutes for those modules instead of running just one module.
          Have you ever done something similar?
          Thanks in advance
            Thanks J M Fahey,
            I have the one with the heavy big thoroidal and the two modules with class AB mosfets.
              Ok, how many MosFets per board?
              They use the same circuit in all amps , not their own desigh but a Hitachi MosFet application example, straight from the datasheet, just with various supply voltages and more or less output transistors.
              Largest I have ir AH500 , meaning 2 x 250W modules with 4 MosFets each; suspect yours is same but with 6 transistors per module.
              At least similar Ashdown Mag 500 has the same circuit with one module and 6 transistors.
              Nothing new under the Sun.
              Check whether this roughly matches what you have.
              personally I would repair the dead module, to the extent of cloning its PCB if original is destroyed, go figure.
              It is a very simple and nrobust amplifier, eqasy to service in the future, and you already have all the hardware mounted in the proper place (specially heatsinks).
              Worst case go the Class D route, but you will have to mechanically adapt them to fit "inside a suit made for somebody else" and consider them disposable if anything happens.
              Or plain pull the dead Class AB module and just use the working 500W one , as suggested above.
                Hi Juan Manuel,
                I'll be out for the entire week, I will give you the right answers (and maybe a photo) this weekend.
                I remember six or eight MosFets, but I want to give you a correct answer not to waste your time.
                Clone the PCB would a bit over my capabilities, also because alot of components on the power amp are smd.
                I will give you better answers in a few days.
                  Ok, I was thinking you might have the earliest ones which used through hole components.
                    I've found a photo of an amp like mine, it's actually the same Jazz P Bass posted few posts ago.
                    Power amp modules are a mix of SMD and hole through.
                      Some more photos of the broken module (more on the following posts).
                        Some more will follow
                          Some more...
                            Even more...
                              Last triplet of photos.
